Message 1 of 6
Re: BT 900 upload changed to 50Mbps and other issues
@JohnC2  Hi John, I have the same issue with upgrade to 900. Upload capped at 70. Are you able to help?
5 REPLIES 5
Message 2 of 6
@Bars
It can take 2/3 days after the change to fibre 900 for the up speed to get to correct speed. Have you been connected for 3 days since your change to fibre 900?
Message 3 of 6
Yes, 900 was activated 3 days ago. Had BT home tech guy out today but wasn’t aware of the issue. I have also tried a factory reset but still not exceeding 70mbs upload….
Message 4 of 6
What about up connection not the upload speed which is different
Try using fast.com and see what speeds you get
Message 5 of 6
160MB….I think (using fast.com)
Message 6 of 6
Hi @Bars,
Thanks for reaching out to us.
I have sent you a private message so we can look into this for you.
It may take a couple of working days for us to get back to you.
DanielS
