Message 11 of 12
Re: Fibre 1 downgraded?
The stats from your router only show an uptime of 19 hours , so it’s been recently disconnected anyway , using the master socket test port should eliminate any dodgy extension wiring or sockets, so always a useful thing to do , if on digital voice , the 17070 quiet line test won’t assist, but it’s possible your line is impacted by an external issue.
Although the checker won’t work with a DV phone number , it should with your address or UPRN
Message 12 of 12
It's changed again today to
This is a list of your Hub settings and current statistics.
Product code:Hub
Serial number:+091299+1841001896
Firmware version:v0.39.01.04077-BT
Firmware updated:Thu Jun 22 02:21:20 2023
Board version:R01
GUI version:1.77 20_05_2022
DSL uptime:0 days,11 Hours49 Mins25 Secs
Data rate:14.993 Mbps / 54.999 Mbps
Maximum data rate:27.818 Mbps / 92.725 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:15.9 / 15.9
Line attenuation:8.5 / 12.9
Signal attenuation:8.3 / 14.0
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:1.2 GB Uploaded / 27.2 GB Downloaded
Broadband username:[email protected]
Public Wi-fi status:Activated
2.4 GHz wireless network name:BT-J8A37H
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-J8A37H
5 GHz wireless channel:Channel: 48
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:44:FE:3B:13:27:CF
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
