Message 1 of 12
Re: Fibre 1 downgraded?
Hi
I have similar issue.
My broadband has been working perfectly for many years, yet today I notice my current package shows as 50Mb download speed with 41Mb guaranteed, whereas previously it was 74Mb Download speed with guaranteed 60Mb.
My speed test indicates, indeed I have been downgraded to a 41Mb exactly.
I have made no changes so this must have been done centrally without informing me.  Sounds like they have done same to other customers too.
11 REPLIES 11
Message 2 of 12
Nobody has done anything to anybody, what would be the point. Strange as it might seem lines go faulty.
Message 3 of 12
I have moved you onto your own thread so that you can get answers to your problem and avoid confusion with the OP's answers of the thread that you posted on.
Message 4 of 12
 please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal. Provided you don't have digital voice
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problemf
Message 5 of 12
I'm router currently shows
This is a list of your Hub settings and current statistics.
Product code:Hub
Serial number:+091299+1841001896
Firmware version:v0.39.01.04077-BT
Firmware updated:Thu Jun 22 02:21:20 2023
Board version:R01
GUI version:1.77 20_05_2022
DSL uptime:0 days,19 Hours32 Mins21 Secs
Data rate:13.205 Mbps / 45.836 Mbps
Maximum data rate:12.268 Mbps / 43.149 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:5.2 / 5.2
Line attenuation:24.4 / 28.7
Signal attenuation:24.1 / 31.6
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:43.1 MB Uploaded / 3.5 GB Downloaded
Broadband username:[email protected]
Public Wi-fi status:Activated
2.4 GHz wireless network name:BT-J8A37H
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-J8A37H
5 GHz wireless channel:Channel: 48
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:44:FE:3B:13:27:CF
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 6 of 12
On below site
when entering landline phone number it says:
There is no data available for this number. This could either be as it is a new BT line, or it is a new BT number which has just been provided.
Really weird as I have not changed anything for years (and yes I did check I was entering correct number several times)
Message 7 of 12
Hi @Neeps, although you've mentioned that you've not changed anything in years can you just confirm that you've not been moved over to Digital Voice for your telephone service as that could explain this message.
Cheers
John
Message 8 of 12
your stats show your actual connection speed is slightly better than your attainable speed!
have you tried using the test socket which is behind the master faceplate - you will need to use a filter
Message 9 of 12
Appreciate people proving useful advice here, apologies I started off as a bit of a moan👍
Re Digital Voice - I did get an email notification sometime in 2021 that I'd been moved over.
On the test socket piece, I'm a bit worried that disconnecting/reconnecting will make the situation worse, so will try after work.
Message 10 of 12
as now on DV you can use your address in dslchecker and post results
