Message 1 of 5
Re: Speed guarantee claim question
So who do I contact in BT about this (please don't tell me 150)
4 REPLIES 4
Message 2 of 5
Message 3 of 5
Doesn't answer my question tho'
Message 4 of 5
If it reports that there is an issue with your speed, then you book a visit from Openreach to investigate. Remember quoted speeds are connection and not download speeds.
Message 5 of 5
As mentioned if you believe you have a fault it can be reported online an engineer booked if needed.  If you would rather to speak to someone then speak to the technical support team who will run a test for you.
