Message 1 of 3
Setting up a Asus DSL-AX82U AX5400 Dual Band Modem Router
Hi all this my first post here. I need some help to set up a Asus AX82U modem router in place of my BT Smarthub.
I have set it up but it does not have any internet connection. My current setup is FTTC  I know I need to put in [email protected]   also my BT SSID plus  VLAN ID 101 but it does not pick up the connection. At the moment I am using the bt Smarthub2. I have the GFAST line
Is there any other setting I have to change to get this modem router working. I am not a tech expert hence me coming on here.
Thanks in advance
All help greatly appreciated
2 REPLIES 2
Message 2 of 3
Re: Setting up a Asus DSL-AX82U AX5400 Dual Band Modem Router
@Kippershed
That Asus is not compatible with a G.Fast line I'm afraid.
The only Asus that is is the DSL-AC88U as far as I'm aware.
There aren't many devices that are GFAST compatible , I think Netgear and Draytek do one and maybe TP-Link as well.
Message 3 of 3
Thank you for your response
