Message 1 of 11
Fibre 2 - Stuck on Fibre 1 profile
I seem to have the same issue, ordered Fibre 2 but provisioned to Fibre 1 @JohnC2  would you be able to take a look at my setup. An engineer was booked for Friday to resolve as there was also a fault identified on the line when the test was run.
10 REPLIES 10
Message 2 of 11
Re: Fibre 2 - Stuck on Fibre 1 profile
Good morning @MancLad,
Thanks for taking the time to post up last night.
I've moved your post onto a thread of your own.
I'll check your account and see if we can get this sorted for you.
Check your private messages as you will have a message from me.
DanielS
Message 3 of 11
Hi @MancLad, the order to correct your profile has now completed. Please you would check and let me know that your speeds have improved?
Cheers
John
Message 4 of 11
Doesn’t look to have worked I rebooted the hub also.
Message 5 of 11
Did you message the mods to let them know
Message 6 of 11
@JohnC2  Doesn’t look to have worked.
Message 7 of 11
Thanks for the prompt to nudge the Mod.
Message 8 of 11
Hi @MancLad, thanks for checking that for me and posting back. I'm sorry it hasn't worked this time. I'll get the request placed again.
Cheers
John
Message 9 of 11
Hi @MancLad, the team has get back to me to say some deign work needs to be completed and your profile should update on the 5th of June.
Cheers
John
Message 10 of 11
@JohnC2  this has now completed, thank you for your help.
