Message 1 of 3
Should I Upgrade to the Smart Hub 2?
Hello
My contract is up for renewal and for a similar monthly price, one of the packages now comes with the Smart Hub 2. I currently have the Smart Hub 1 with three BT Mini Whole Home Wi-Fi discs due to poor signal spots in some parts of the house.
I know that the Mini Whole Home Wi-Fi would not be compatible with the SH2 but at the same time the sales pitch for the SH2 says it is much better Wi-Fi range, speed and connectivity.
I was therefore wondering, is it worth upgrading to the SH2 or just pick a package but say no thanks to the SH2 and keep my existing setup?
Many thanks
2 REPLIES 2
Message 2 of 3
Re: Should I Upgrade to the Smart Hub 2?
keep your existing setup if it works for you as no point in the SH2 unless existing setup is causing problems
I doubt SH2 has any better wifi and causes problems with some customers as you cannot split the wifi networks
Message 3 of 3
If it ain't broke, don't fix it.
