Message 71 of 83
Re: YouTube Buffering and Slow Loading on BT Full Fibre 900 – Possible Routing/Peering Issue
@Steve_M Appreciate it, can confirm back on ***---sn-cu-cime7 and not having any issues whatsoever currently
Message 72 of 83
Thankyou
Anonymous
Not applicable
Message 73 of 83
Re: Slow Seek times with YouTube
use a diffrent dns see if this fixes it
Message 74 of 83
@Anonymous
You're a bit late 😅 BT have already implemented a fix based on what we fed back.
It's not DNS.
Anonymous
Not applicable
Message 75 of 83
i was not at the time tho was i there before steve M posted
Message 76 of 83
@Anonymous
It was solved on the 9th, Steve M was just confirming the two problematic nodes were added back in
It's a long thread though so understandable, @gizmo777 It might be worth marking this as solved now?
Message 77 of 83
@tyencyu I’m on vacation until Friday so cannot check until then
Message 78 of 83
Seem to be having issues again this evening.
Message 79 of 83
It seemed to be crapping out quite a bit for a few minutes, It seems to have stabilised a little for now which might just be normal failover behaviour, Stats for nerds seems to show lower than normal kpbs and shorts did drop to something like 611kbps.
A bit erratic, I guess heads up @Steve_M
Message 80 of 83
Yeah mine collapsed to 64Kbps… seems to have recovered a bit now.
