Message 1 of 3
Slow bordband
Hi Not sure what any of this means , my bordband been slow for 3 weeks , dose this look normal ??
2 REPLIES 2
Message 2 of 3
Re: Slow bordband
That is the results of dslchecker showing estimated speed but say nothing about your actual connection. You need to post stats from your router and assuming SH2 go to hub manager then advanced settings then technical log information and post the hub stats you can see - not the actual logs
Message 3 of 3
Re: Slow bordband
Wow thanks for the help I will do that by
