Message 11 of 13
Re: Slow broadband and glitches a lot
Those are 99% certain to be scam calls.  What they’ve said is nonsense.  Do not respond to anything they want you to do.  It will be a con.
As far as the TV connection goes, it’s most likely to be interference from something.  The first thing to try is to go into the hub management page on 192.168.1.254 and change the wireless channel to a different channel.  It’s probably the 2.4GHz channels but only you would know if it were 2.4 or 5GHz.  Either way, a change of channel may help.
Message 12 of 13
Thought so I did not respond to it
Message 13 of 13
Welcome to the Community @Kathleen62.
I'd definitely recommend trying the channel change @WSH mentioned here.
If you're noticing issues on other devices as well, I would recommend giving our troubleshooter a try, which will run through some steps to help fix your connection, and if needs be help you get an engineer appointment or call back from our team.
Keep us posted on how you get on.
Peter
