Message 1 of 5
Speed Test
I had Full Fibre 900 installed on 28/12.
Since then the BT speed test hasn't worked & fast.com results vary from 320-420 mbps.
Do I need to wait a little longer or could there be an issue?
Cheers
4 REPLIES 4
Message 2 of 5
Re: Speed Test
Are you running the test with ethernet connection between hub and device- not WiFi
If ethernet and not improvement by Wednesday then post back
Message 3 of 5
Re: Speed Test
Hi @RoughJustice and welcome to our community.
Thanks for posting about your connection speed. Are you seeing the same results on all devices? As @imjolly has mentioned. Give it a few days and post back if you don't see any improvements.
Cheers
David
Message 4 of 5
Re: Speed Test
All good now.  Seeing 900 - 1000mbps down & 100-120 up!
Message 5 of 5
Re: Speed Test
You were spot on:  WiFi 220-420 mbps.  Ethernet connection 900-1000mbps.
Thanks for the advice.
