Message 1 of 3
Speed Tests
Hi, I’ve recently upgraded to Fibre 900.
On install day, the speed test was showing 650, however 3 days later, the speeds have dropped to around 225, lowest being 165, increased contract but a slower speed tha I was on Fibre 500
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Speed Tests
Wifi speeds fluctuate and no isp will guarantee wifi speed.
Having said that I'm assuming you're using a SH2.
Speaking from experience going from 500mbps to 900mbps on a wifi 5 router  is completely pointless as you will not notice any difference over wifi in the everyday world.
To take full advantage of a 900mbps package over wifi you'll need a wifi 6/7 router.
Message 3 of 3
Re: Speed Tests
Thanks, might need to confirm which one I have and upgrade the router, much appreciated
