Message 1 of 19
Speed upgrade!
Hi hoping someone can look into this for me. I recently had a line fault that was repaired and my speeds were 52up 10 down, but after the fault 44down. I was told the DLM might need a reset. Yesterday i went on my bt account to discover i can have a speed boost onto infinity 2. The upgrade said 55 min speed- 60 to 64 speed. I was rather excited at the news eagerly pressed the upgrade button!.
I waited over night and like Christmas morning checked for the new speed...... I checked the speed test on my phone to discover ive gained one MEG!. I couldn't believe my eyes. I was expecting the line to be glowing but sadly not. I would apricate it if someone talk nicely to the dlm, and let a few more horses out. Screenshot (15).pngScreenshot 2022-02-23 111945.pngIMG_6940m.jpg
18 REPLIES 18
Message 2 of 19
Re: Speed upgrade!
please can you check MYBT that package shows fibre 2 as your speed according to stats is 55/10mb which is the fibre 1 speed max
however according to dslchecker results you had 74/10mb on 6 Feb.  are you have connections problems maybe resetting hoping speed will improve?
Message 3 of 19
Re: Speed upgrade!
Hi Yes the package is fibre 2 that's what i ordered. I don't have any line problems now, well not that i know to.
I restarted the router this morning the sync speed has gone up.
Message 4 of 19
Re: Speed upgrade!
can you post new stats
Message 5 of 19
Re: Speed upgrade!
Message 6 of 19
Re: Speed upgrade!
Message 7 of 19
Re: Speed upgrade!
Sorry duplicated
Message 8 of 19
Re: Speed upgrade!
you now need to maintain a stable connection with no reset and you should get a speed boost when DLM kicks in G.INP.  your noise margin would normally drop to about 3db giving increase in speed  can take 10/14 days stable
Message 9 of 19
Re: Speed upgrade!
Thanks I’ll keep an eye on it
Message 10 of 19
Re: Speed upgrade!
1C35010D-EF9C-4677-92FC-C74D144BE416.pngHaving speed issues can’t watch programmes from apple and the error rates are going through the roof. I checked the speed and it dropped to 25 mbs.
Does this indicate the line still has problems.
