Message 1 of 3
Two lines and ipv6
I have two lines providing fttp and only one has a working ipv6 the other just provides an ipv4 address.
If you swap the lines round the ipv6 address moves with the line.
Is this deliberate policy by BT or has someone just forgotten to enable it?
2 REPLIES 2
Message 2 of 3
Re: Two lines and ipv6
Hi @ipc6023, sorry you're not getting ipv6 on both your fttp connections.
Has the connection that it isn't available on only recently been upgraded?
cheers
John
Message 3 of 3
A quick further test this morning and it's seems to be a limitation of the draytek that only allows ipv6 on one interface.
In the past I wondered what happened when you had two different providers with ipv6 and nobodies been able to answer that question.
I guess the answer is that you can't
