Message 11 of 18
Re: Upgraded from fibre essentials to fibre 2 but speeds to hub haven’t increased
Indeed, that would be my guess.
Message 12 of 18
Message 13 of 18
yes it is strange, above is what my BT app says
Message 14 of 18
Any advice as calling BT was hopeless yesterday?
Message 15 of 18
It’s a bit if a shame , this is the kind of issue the previous moderation team would have taken on board , got resolved and posted back , unfortunately the moderation policy seems to Have  changed and it seems to be now the moderator will simply suggest contacting customer support, even though you have already done that , FWIW , it seems you are indeed still on the 40/10 Mb profile
Message 16 of 18
try using message now in billing and see if they can help or direct you to someone that can  your upgrade has not been processed as others have said
https://www.bt.com/help/contact-bt/account-and-billing/broadband
Message 17 of 18
Thank you for your advice, they have run remote tests and attempted to reconfigure router bit speeds still 36mps not 49-50mps
they are convinced the speeds should be possible and are included in new package
engineer visit to check external factors
Message 18 of 18
It has nothing to do with your router or anything an Openreach engineer calling at your home can deal with. It is a Software Billing issue that needs BT need to amend in order to lift the speed cap on your previous broadband package.
