Message 1 of 18
Upgraded from fibre essentials to fibre 2 but speeds to hub haven’t increased
Upgraded from fibre essentials to fibre  2 two days ago but speeds to hub haven’t increased
fibre essentials package 37 mps
uograded to fibre 2 (49-50mps) but still getting 37 mps.
On BT app order complete and package details now say fibre 2( 49-50) minimum 44.
ive reset hub but no change, tech support not helpful. Hub stats say download speed 40mps and maximum is 59mps
17 REPLIES 17
Message 2 of 18
Re: Upgraded from fibre essentials to fibre 2 but speeds to hub haven’t increased
@rothwelljohn7
Your line may not support a faster speed.
Use the address checker on the page below, and post the results, but edit out your address details first, but leave the exchange name and cabinet number showing.
Please include all notes at the bottom.
Message 3 of 18
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability WBC SOGEA AvailabilityHigh Low High Low      VDSL Range A (Clean) rothwelljohn7_0-1737186874243.gif
59.643.110.87.235UnavailableAvailable
57.836.610.66.532.4UnavailableAvailable
----------Unavailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
1000220--Available--
Other Offerings Availability DateVDSL Multicast
Available
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
Y
N
FTTP is not available.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules.CPs should order FTTP or SOGEA. Copper products are only available by exception.
Thank you for your interest
Message 4 of 18
Expected connection speed 43.1 to 59.6, so your hub speed is just slightly lower than this. It could take 10 days to increase, but you must not restart or disconnect the home hub, as that will be seen as a possible fault, and the connection speed would not increase.
What is the downstream noise margin showing, on the home hub stats?
Message 5 of 18
Message 6 of 18
I did reset the hub as advised by BT tech support but I won’t do this again
Message 7 of 18
Downstream noise margin is high at the moment, but this will reduce, and the connection speed will increase, once DLM (Dynamic Line Management) decides that the line is stable, with a low error rate.
For an explanation see https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
Do not let the helpdesk do any resets.
Owing to your distance from the cabinet, the upgrade is unlikely to make much difference to the actual download speed.
Message 8 of 18
Thank you for your support, that is reassuring
I will hold tight!
Message 9 of 18
DLM normally causes a re-sync, not a restart, whenever the parameters change. You may not notice it, as I think it does it overnight. You can check it yourself after about a week.
Unfortunately its not a fast process, so it may take longer than 10 days. If you check the connection speed, it should eventually end up being within the range BT has specified.
Bear in mind that the download speed, measured on a direct Ethernet connection, will always be lower than the actual connection speed. BT only guarantee the connection speed.
Message 10 of 18
@rothwelljohn7
According to your hub stats it looks like you're still on the Fibre Essentials product. It's as though your regrading hasn't been applied.
