Message 5 of 11
What do this mean
  • 19:35:34, 24 Sep.Has a problem to connect to SAAF framework (5 times11:15:37, 29 Sep.Has a problem to connect to SAAF framework (7 times)11:15:37, 29 Sep.Has a problem to connect to SAAF framework (7 times)11:15:37, 29 Sep.Has a problem to connect to SAAF framework (7 times)
10 REPLIES 10
Message 1 of 11
What do can't connect to SAAF frameworkmean
Message 2 of 11
Re: What do can't connect to SAAF frameworkmean
In relation to what?
Message 3 of 11
It's in my event log on the bt smart hub 2
Message 4 of 11
No Idea.
A quick search shows that the question has been asked before but there doesn't seem to be an answer. My guess would be that it means that the firewall is doing its job.
Search - BT Community
Maybe one of the mods ( @NeilO or @DavidM ) could advise
Message 6 of 11
Re: What do this mean
SAAF stands for soft reset but the rest ?
This question has been asked a few times over the last couple of years but there doesn't seem to be an answer.
Search "SAAF" in the search bar above
Message 7 of 11
Do u think I could be hacked 07:26:15, 06 Oct.Has a problem to connect to SAAF framework (18 times)
011:15:37, 29 Sep.Has a problem to connect to SAAF framework (7 times)12:50:11, 25 Sep.Has a problem to connect to SAAF framework (5 times19:35:34, 24 Sep.Has a problem to connect to SAAF framework (5 times7
Message 8 of 11
No Idea. It's in my event log as well so I hope not. there are other similar posts on this forum so maybe there is a vulnerability of some kind which hackers are attempting to exploit or perhaps it's just a sign that the firewall is doing it's job.
Maybe one of the moderators could pass the enquiry on to the hub team? @DavidM  or @NeilO
Message 9 of 11
@Martyngammon @Les-Gibson I've asked the question, I don't think it's anything of concern and I'll post back here when I get an answer.
Neil
Message 10 of 11
Many thanks @NeilO  👍
