Message 11 of 11
Re: What do this mean
Hi @Martyngammon SAAF stands for Smart Applications Analytics Framework.  It’s an application plugin (developed by BT) that allows additional functionality to be deployed to the Hub without the need for a full firmware upgrade of the hub itself.  It’s primarily used to deploy a range of Smart Diagnostic applications to help improve our diagnostics of the hub and extract key diagnostic and status data from the hub in order to improve customer experience and improve troubleshooting problems.
The Hub team will be happy to look into what's triggered these logs if you'd like and I'll send you a private message if you want to get in touch.
Neil
