Hello, I hired bt recently and it arrived today. I have tried to plug it in but the broadband does not fit. could a technician come to install a new one to be able to use my wifi? thank you
Does your phone socket only have one outlet on it? If so you need a filter dongle which has the 2 outlets so that you can plug in the phone and broadband.
You should have been supplied with one, if not give customer support a ring.
Hi @Kellyhernanddez and welcome to our community.
@pippincp advice is sound but I'd like to take a look at your set up. Can you post a picture of the socket?
Cheers
David
which master socket do you have
