Message 11 of 13
Re: broadband continually dropping out
i'll try ethernet connection (my comment about not being tech savvy was about changing wifi channels!)
Message 12 of 13
does the WiFi disconnection affect all devices at the same time? - sometimes things closer to the hub still get wifi, but others don't
Message 13 of 13
if you go to hub manager 192.168.1.254 into browser address bar then enter admin password then got to advanced settings/wifi and you should be able to change 2.4/5ghz channels there and remember to save when you exit
