Message 1 of 5
if bt are build for FTTP how long does this take
if it states building in my area how long will this take to complete ?
4 REPLIES 4
Message 2 of 5
Re: if bt are build for FTTP how long does this take
How long is a piece of string, mate?
Could be weeks, months, a year or, (if they hit a significant problem in your street), abandoned altogether.
In my own case, in the region of six months, but I have family up and down the country and they tell me varying times.
Message 3 of 5
BT don’t build Openreach are.
How long takes maybe on wot works needs doing. Cud be 2 weeks cud be 2 months.
Message 4 of 5
@shakey1981  You should perhaps ask the AI bot who started this thread:
https://community.bt.com/t5/The-Lounge/FTTP-REF-VOL/td-p/2456132
Message 5 of 5
The really simple answer is, until it is finished.
