if it states building in my area how long will this take to complete ?
Solved! Go to Solution.
How long is a piece of string, mate?
Could be weeks, months, a year or, (if they hit a significant problem in your street), abandoned altogether.
In my own case, in the region of six months, but I have family up and down the country and they tell me varying times.
BT don’t build Openreach are.
How long takes maybe on wot works needs doing. Cud be 2 weeks cud be 2 months.
@Anonymous You should perhaps ask the AI bot who started this thread:
https://community.bt.com/t5/The-Lounge/FTTP-REF-VOL/td-p/2456132
@Anonymouswrote:if it states building in my area how long will this take to complete ?
The really simple answer is, until it is finished.
