Message 1 of 2
Add on Removal
Hi,
I bought a 5GB data add on last month. I've been trying to remove it as I dont need it going forward as I plan to upgrade my data plan (5GB to 20GB) but have been unable to get confirmation of it being removed? Is there someone that can help me or should I just call support.
Tags (5)
1 REPLY 1
Message 2 of 2
Re: Add on Removal
Just contact CS 150 or 0800800150 from mobile and they should be able to help you
