Message 1 of 4
PAC Codes
Hello
I hope someone from BT can help, i have 3 SIMs and I want PAC codes for all of them to move to another provider, texting PAC to 65075 does not work and when i go through the BT website to request a PAC code nothing happens (I've tried chrome and edge browsers as well as my mobile)
I am at work today so haven't got the time to sit on hold and speak to someone, can anyone help?
Ed
3 REPLIES 3
Message 2 of 4
Re: PAC Codes
as you have multiple sims then you may be able to get code in MYBT or phoning 150 or 0800800150 from mobile
https://www.bt.com/help/mobile/how-do-i-get-a-pac-
Message 3 of 4
Re: PAC Codes
Hello
MYBT is broken, when i click request it fails to load.
Looks like i'll have to spend my lunch break on the phone 😞 I though switching was supposed to be easier these days!
Message 4 of 4
Re: PAC Codes
Looks like I have the same problem as you, did you ever get it working via the website or did you have to phone them ?
