Message 1 of 4
BT mobile Network not connected in Rome like home country
I'm in Greece just now and my BT Mobile network won't connect. Have checked Roaming is set to On on my device, restarted the phone as well.
I had the same problem a few months ago when I was in Switzerland.
I can get data through WiFi but unable to receive normal calls and SMS due to no mobile network for my phone number.
Any help appreciated.
3 REPLIES 3
Message 2 of 4
Re: BT mobile Network not connected in Rome like home country
You need to enable roaming on your account via MyBT and set a minimum extra spend, £10 normally covers it.
Message 3 of 4
Thanks. Tried to check mybt settings at www.bt.com/mymobile as this is the link shared on most help and support pages. But that takes me to a 500 error page.
Any particular place in MyBt app where I can enable roaming a I can't find the setting ?
Message 4 of 4
should login to MYBT then select my products then mobile and you should be able to check/make changes there
