Message 1 of 4
BT mobile
About 2 weeks ago I received a text allegedly from BT Mobile saying that they'd updated some of my network settings and asking me to restart my phone to make sure it's up-to-date. I'm a bit suspicious so was just wondering if anybody else has had this same message? TIA
3 REPLIES 3
Message 2 of 4
Re: BT mobile
See link
Solved: Is this a scam - BT Community
There may be other posts regarding this if you do a search.
Message 3 of 4
Re: BT mobile
@cwmoss
Welcome to this user forum for BT Retail phone and broadband customers.
Everybody got that same message, and needed to restart their phones to re-establish network connectivity.
I suspect it was related to the migration to EE, which involved some parameter changes.
In my case, I had a SIM error message until I restarted my phone.
Nothing to worry about.
Message 4 of 4
Re: BT mobile
If you have an iPhone - and you go to Settings>Your Name>Subscriptions, you'll find at the bottom of the page 'EE Plan Benefits'. Tap on that and you'll find there are probably none. I think that was the update.😞
