Message 1 of 6
BT or not BT pop up
Hi all.
Wifey keeps getting this pop up on her samsung galaxy phone, on BT mobile.
Suspect it's not a genuine advert for BT.
I have run an AVG scan, nothing gets picked up.
Any thoughts?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: BT or not BT pop up
Given that Samsung are about to release the S23, a prize of an S20 seems fairly unlikely.
Edit: This is similar from 2020:
https://community.bt.com/t5/Announcements-Guides-Community/Beware-Survey-popup-scam/td-p/2040918
Googling “BT pop up scam” produces several similar threads over the years.
Message 3 of 6
Thanks,
Message 4 of 6
Hi @Devon_Dave That's a scam, if your wife is using the chrome browser on her phone there is an option in the browser settings to block pop-ups.
Neil
Message 5 of 6
Thanks Neil, will check it out.
Message 6 of 6
Today, June 11th 2024, this same scam has ‘popped up’ on IPad using Safari, how do I block pop ups?
