Message 1 of 5
Cannot connect to network in France
I am in France at the moment and cannot connect to a network please help.
4 REPLIES 4
Message 2 of 5
Re: Cannot connect to network in France
have you set you phone in MYBT to have ability for international calls?  if so have you set international spend limit to a sum greater than £0?
Message 3 of 5
Hi @comcab1 and welcome back.
@imjolly advice is good. Please check your MYBT for the spend limit and let us know if that helps.
Cheers
David
Message 4 of 5
Thank you for helping, found a Asda sim in my in box of stuff topped it up then phoned BT. Sorted        Thanks again.
Message 5 of 5
Thanks for letting us know @comcab1
Cheers
David
