Message 1 of 7
4G to 5G
My new mobile phone is 5G enabled but my BT SIM card is 8 years old and I’m on a 4G plan
How can I change to a 5G plan and will I need a new SIM card?
6 REPLIES 6
Message 2 of 7
Re: 4G to 5G
You'll need to call BT Mobile and request a 5G SIM and account.
Message 3 of 7
Re: 4G to 5G
My understanding is that 5G is the network platform and the sim should not matter.
I have what could be called a 4G sim and when I enter a 5G area it works just fine.
Message 4 of 7
Re: 4G to 5G
You might find this link helpful; Do I need a new SIM card for 5G?
Message 5 of 7
Re: 4G to 5G
@West a lot of older Sims aren't compatible with 5G
Message 6 of 7
Re: 4G to 5G
In case it helps anybody else, I can confirm that because my existing SIM is 8 years old, I did need a new SIM card.  Thanks to everybody for their help.
Message 7 of 7
Re: 4G to 5G
Thanks for letting us know @speechless .
Cheers
David
