Message 1 of 4
Does PAC processing close BT mobile billing?
Hi. I currently have BT broadband and BT mobile.  The contract term in both cases recently ended.
I've just renewed the broadband, but want to move to a different mobile provider.  If I get a PAC code from BT, then give that to a new provider, will that supplier's one-time use of the PAC code trigger BT to stop charging me the monthly mobile charge?
It'd be nice if it happens automatically like that, rather than having to phone BT to cancel.
3 REPLIES 3
Message 2 of 4
Re: Does PAC processing close BT mobile billing?
Yes! You've just described exactly what a PAC code is for!
Message 3 of 4
Using the PAC code to a new provider to transfer your phone  number should automatically cancel your BT mobile contract
Message 4 of 4
Hi @wdblue  You can find more information on a PAC and how to use it via this link: BT Mobile PAC
Chris S
