Message 1 of 5
Lost sim help
So I lost my old sim but replaced it with another. Does that mean the old one is of no use anymore or do I have to phone to report it lost?
4 REPLIES 4
Message 2 of 5
Re: Lost sim help
Hi, @MissBeatty welcome back to the community and thanks for posting. You don't need to do anything else as the lost sim won't work anymore if a replacement has been sent and activated.
Neil
Message 3 of 5
Re: Lost sim help
@NeilO @MissBeatty
The OP does not say she explicitly requested a replacement for a lost SIM. If she had, she wouldn't have asked whether to report the original being lost.
Doesn't a replacement for a lost SIM have the same phone number?
Message 4 of 5
Re: Lost sim help
Yeh just asked for a replacement didn’t say it was lost. It was in the house i was pretty sure but now im thinking there’s the small chance it isn’t.
Message 5 of 5
Re: Lost sim help
Hi, @MissBeatty That's ok, if you asked for a replacement and it's the same number then you don't need to do anything else.
Neil
