Hi, could one of the mods please advise the best way to move several mobile numbers from one of my accounts to another as I want to close the account they are currently on?
Hi, @draytonr Thanks for posting, the mobile team should be able to arrange an account merge to transfer the mobiles to your other account.
If you get in touch they'll be able to make the arrangements From BT mobile 150. From the UK 0800 800 150
Neil
Thanks but I've tried that and the agent suggested that it's not straight forward (due to me having a family SIM) and suggested migrating my broadband instead of the mobiles which isn't an option.
Why isn't there an email contact for the mobile team? I'd appreciate some support to get this resolved as I see has been provided to other forum members with the same issue.
@NeilO are you able to assist here??
@JohnC2 are you able to help here please as I see you have helped others with the same problem. Thanks
Hi @draytonr, I'm sorry but the Mod team can not help you with this. You will need to get in touch with the BT Mobile team.
John
Really helpful thanks.
