Message 1 of 7
Mobile signal
The mobile signal in my house is now non-existent, it was fine until yesterday.  Now none of our 3 phones can get a signal not can the Halo box
6 REPLIES 6
Message 2 of 7
Re: Mobile signal
Sounds like an issue with a local mast if all devices aren't able to get a signal.
What does it show if you check the status of the network at this website using your postcode- https://coverage.ee.co.uk/coverage/ee
Anonymous
Not applicable
Message 3 of 7
Re: Mobile signal
Already covered.
Message 4 of 7
Re: Mobile signal
Thanks for the reply but the coverage map hasn’t changed
Message 5 of 7
Re: Mobile signal
Anonymous
Not applicable
Message 6 of 7
Re: Mobile signal
You're not looking at the coverage map but "Check Status".
Message 7 of 7
Re: Mobile signal
Ah! Yes, thank you
