Message 1 of 7
Moving a Family mobile plan to another provider
Hi. I am leaving BT broadband and now want to move my BT family sims onto another provider also. I have a PAC code for my sim but do I need a separate PAC code for the other sims/numbers on the family plan? Thanks, Nick
6 REPLIES 6
Message 2 of 7
Re: Moving a Family mobile plan to another provider
Even if you move from a BT family SIM plan to EE you need a PAC code for each number you are transferring so it would seem logical that the answer to your question is that you will need a code for each one
Message 3 of 7
Hi @nhsix, the advice given by @Les-Gibson is correct. The PAC is to allow your number to be moved so you'll need a PAC for each phone number.
Cheers
John
Message 4 of 7
Many thanks
Message 5 of 7
Perfect, thank you
Message 6 of 7
I have asked BT for separate codes and they say the same one will work for both numbers
Message 7 of 7
This has came up on here at least twice before if I remember. Fact is you can have 1 pac for multiple numbers but some of the smaller networks & their systems can't handle that standard process so insist of 1 pac for 1 number
