Message 1 of 3
No data roaming in Malta
Hi
i have recently used mobile data roaming in Spain without any issue but I can not get a network connection in Malta on my iPhone 12 Pro even though my friend can. I have tried to trouble shoot by doing the following.
1. Forced reboot of phone
2. updated latest IOS version
3. reset network settings in settings>general
4. Disabled and re-enabled data roaming
5.turned phone on and off
6. turned flight mode on and off
7. turned off automatic network and chosen local network
Can anyone help, please?
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: No data roaming in Malta
Have you activated international calls in MYBT and also set the international spend cap to greater than £0  say £5
Message 3 of 3
if you recently used in Spain I would have expected no problems in Malta.  can you check MYBT that mobile is set for using abroad and that the spend limit is set to higher than £0 say £5
