Message 11 of 21
Re: No service on mobile
Assuming you are on Digital Voice, I suspect that your mobile is trying to use Wi-Fi calling and your hub is not playing nicely, hence you can use neither landline nor mobile.
Try switching your hub off and then try to make a call on your mobile (whilst the hub is still off), then turn your hub back on and try making another mobile call.
Message 12 of 21
Thank you. I switched both hub and mobile off. Mobile back on again, it's reset itself and I've been able to make a call. Hubs back on now and made another call. Just need batteries now to try and sort my home phones out. Thanks everyone xx
Message 13 of 21
Same here in Leeds!
Message 14 of 21
Just curious, are you able to use mobile data? (I can make calls but can't use data/can't connect to anything.)
Message 15 of 21
Hi, yes, once I'd switched the mobile off and back on again it was working fine
Message 16 of 21
No only my sky wifi
Message 17 of 21
Hi @SPE
Is it only within a specific area you're getting no service at all, or is the issue following you no matter the location?
What device are you using?
Have you tried any steps suggested in the thread so far?
Linzi 😊
Message 18 of 21
Hi, @Linzi_H , iPhone 15 and yeh the fault is constant no matter where I am, only started this morning
Simon
Message 19 of 21
Thanks for letting me know @SPE
Can you try resetting the network settings on your iPhone if you haven't done this already? To do this go into Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings.
You won't lose any personal data, but you'll need to provide your password next time you connect to WiFi.
Also, can you check your device is fully up to date please? Just head to Settings >  General > Software Update. If you have an update pending then complete that too.
Let me know how it goes.
Linzi
Message 20 of 21
Hi @Linzi_H
I tried that this morning, however it has now started to work again?? So maybe just a gremlin
Simon
