Message 1 of 2
PAC not appearing
I'm moving to another network so I need to get a PAC. Because I had 2 numbers under 1 account I can't text the general number for the code.
I've logged in and gone to the page to generate a code but nothing happens.
I click on "Get Started" then the button disappears along with the text and I'm left with 3 headings of:
Type of switch
What to expect if you switch
Your switching code
... and a load of FAQ's
Tried this process a few times and no code appears
1 REPLY 1
Message 2 of 2
Re: PAC not appearing
Hi @j_the_geek, welcome to the forum and thanks for your post.
Check out How do I get a PAC? | BT Help and there is a text option and if that fails, you'll need to call in and speak with the Mobile team.
Cheers
John
