Message 1 of 6
Bt Abroad
I am currently in US. My by mobile is not able to make or receive calls. Have checked that I have signal and that international roaming is enabled. I had a 35 minute call from another phone (a friends US phone) with BT in UK but no solution. Any thoughts most welcome and solution needed urgently. Thanks.
PS the message I get when I dial a uk no is “the system is busy… please try later”
5 REPLIES 5
Message 2 of 6
Re: Bt Abroad
Have you also set the international spend limit to greater than £0 say £5. You need that even with data roaming
Message 3 of 6
Re: Bt Abroad
Yes the spend is well above that.
Message 4 of 6
Re: Bt Abroad
Failing the spend cap checks, try turning off the roaming option on MyBT and saving it. It should give you a message saying it takes 30 mins I think to save. Let that do its thing and then do the opposite and turn it back on. once that finishes restart your handset and try again.
Message 5 of 6
Re: Bt Abroad
Thank you for the suggestion. I tried that- stopped roaming, waited, restarted it , turned phone on and off. Still the same message- “ system is busy ….” And still not able to dial out or get incoming calls. Checked the spend limits too.
any other ideas? Thanks
Message 6 of 6
Re: Bt Abroad
Have you tried other networks? I think AT&T is normally preferred but you may be able to connect to other networks and see if that helps?
