Message 1 of 4
Phone stopped working on arrival in Italy
I arrived in Italy 3 days ago and have had “No Service” on my phone ever since.  Multiple calls to BT Mobile Tech Service have failed to yield a solution.  The only development has been that my phone number has been removed from the account (so unless anything changes it won’t even work when I get home !). BT give the distinct impression of not having a clue what has gone wrong.  Any similar experiences out there ? (My wife’s phone which is on the same account is working just fine)
3 REPLIES 3
Message 2 of 4
Re: Phone stopped working on arrival in Italy
Have you set access to international calling and also set spend limit greater than £0 say £5 - check in MYBT
Message 3 of 4
Is your phones network selection setting on Auto? Should be or else it will only ever connect to BT Mobile in the UK.
Message 4 of 4
Do you and your wife have the same phone ?
Android or Apple ?
Have you tried your SIM card in your wife's phone?
