Message 1 of 18
Poor mobile signal at work
Signal strength is acceptable outside but poor inside a modern metal clad industrial unit.
How can I boost the signal inside?
There is no landline or wifi present.
17 REPLIES 17
Message 2 of 18
Re: Poor mobile signal at work
Hi @nilocp   Turn on WiFi calling?
Anonymous
Not applicable
Message 3 of 18
Nothing if Wi-Fi isn't available.
BT/EE don't offer signal boosters anymore unfortunately.
Message 4 of 18
VeteranISPUser, didnt I say there was no Wifi? Please tell me how to do what you suggest.
Message 5 of 18
garetc can you not get other boosters?
Message 6 of 18
WiFi calling is something you turn on in your mobile assuming mobile has capability
Anonymous
Not applicable
Message 7 of 18
EE/BT stopped supporting their own some time ago, there's info on the Ofcom website about repeaters.
https://www.ofcom.org.uk/phones-telecoms-and-internet/advice-for-consumers/advice/using-a-repeater-t...
I think that they can be quite expensive!
Message 8 of 18
If there's no broadband or WiFi available, you're pretty much screwed unfortunately and I feel your pain. Our smoking/vaping area is the buildings inside parking area and mobile signal is very poor on all networks due to the thick concrete and steel walls
Message 9 of 18
Yes they are quite expensive!!
Message 10 of 18
You say there is no Wi-Fi but it's not clear from that if there is a broadband connection, if there is you may be able to provide your own Wireless Access Point
