Message 1 of 2
Remove app/site from adult content filter
We’ve discovered today that if a BT Mobile account has the parental controls set to either strict or moderate (I.e. anything but “off”), the Signal app won’t work. Until a few weeks ago, it did.
Can confirm it’s definitely BT blocking it as it works on the same device if the filter is off or wifi is used.
How do I go about requesting this is removed? Is there a way to add exceptions?
Tags (2)
1 REPLY 1
Message 2 of 2
Re: Remove app/site from adult content filter
Hi @deKay
If you don't think a site or app should be blocked, you can let us know by emailing [email protected]
Neil
