Message 1 of 2
Possibility of obtaining old number
Hi,
I'm wondering if anyone knows whether it's possible to obtain an old mobile number back?
If I try call the number, it says "you've dialed an incorrect number, please check the number and try again".
Am I at total loss here or is it possible if I call BT they might be able to sort something?
1 REPLY 1
Message 2 of 2
Re: Possibility of obtaining old number
you can try CS 03301234150 and see if they can help but I doubt it
