Message 1 of 6
Re: Unable to make advanced settings changes.
My mobile settings are also still greyed out.
5 REPLIES 5
Message 2 of 6
Hi @cherryfan, sorry that your settings are greyed out for the Mobile on your MyBT.
Do you have any open orders on your account at present?
Cheers
John
Message 3 of 6
@JohnC2
I don't see any open orders.
I only tried to increase the monthly spend cap to one of our accounts, 3 weeks ago. And now that we have finished our holiday, I wanted to decrease the spend cap, but it has been greyed out on that account
Message 4 of 6
Hi @cherryfan,
I think we should take a look into this for you and see if we can help.
I'll send you a private message that you can reply back to my team on.
Thank you
DanielS
Message 5 of 6
Hi @cherryfan, the bt.com faults team believe they've fixed the problem with managing the mobile settings. Please would you check and post back to let me know if the fault has been fixed.
Cheers
John
Message 6 of 6
The problem seems to be fixed.
Many thanks
