Message 1 of 8
Roaming - Turkey
Hi
I am in Turkey and I can't get roaming working (not data roaming, just normal roaming).
I can't send or receive texts, or make phone calls.
I have rebooted multiple times, I have tried changing the settings on MyBT - so I definitely have an allowance. And "Using your phone abroad" is enabled.
On my phone (Google Pixel 6) it says: BT (temporarily unavailable).
When I look at the SIM "automatically select network" is turned on as BT recommend.
I have tried turning this off to manually select. In which case I can see that most of the providers including Turkcell are showing: (Forbidden).
Does anyone know what this means?
And can anyone suggest something new I could try to get it working (I have been through this forum and tried everything suggested).
Also how do I get in touch with BT support - I can only find the phone numbers and I can't make phone calls!
Is there a text chat line or something for support?
Many thanks for any help
Pete
Tags (3)
7 REPLIES 7
Message 2 of 8
Re: Roaming - Turkey
Message 3 of 8
Thank you.
I'll try anything that might help.
I have probably misunderstood - but I had assumed APNs were to do with connecting to the internet?
I don't want to use mobile internet, just conventional SMS and phone calls - incoming and outgoing.
Can you clarify for me? Thx
Message 4 of 8
The APN is needed to connect to mobile network not your internet connection
Message 5 of 8
The APN is only necessary for internet access and sending MMS messages, you should be able to make, send and receive calls and text messages as long as your spending cap isn't set too low.
Edit:
"Your device uses something called APN settings to connect to the internet using mobile data and also to send MMS. You'll need to check that your network settings are correct."
BT Mobile: What do I need to do before I go abroad? | BT Help
Message 6 of 8
Thanks both.
Yes, at present I don't have any connection. So no phone, or SMS.
I don't need mobile internet especially.
The phone worked fine in the UK. And I am in Istanbul. So plenty of service.
Message 7 of 8
I seem to have finally fixed it.
I reset all the networking components on the phone using "Reset Wi-Fi, mobile & Bluetooth".
Unfortunately, this also turned on mobile internet and data roaming so I very quickly reached my budget again (not difficult at £1.59 per Megabyte).
This happened in just a few seconds - I assume as soon as data roaming was on, my email syncing alone would have exceeded the budget.
But at least I am connected again.  And I can receive texts.
Presumably as soon as I go on WiFi and increase my budget I will also be able to make calls and send SMS.
Thanks all for your help.
Message 8 of 8
PS In case it helps anyone else, this is what I saw when it wasn't working. Notice no connection at the top. And the word 'forbidden'.
And now when it is working - with data roaming off.
Pete
