Message 1 of 13
Samsung A515 mobile has packed up
My A515 failed with a blank screen. I have since been able to restart it so it displays the basic Android startup screen (see photo). I cannot get any response by tapping, swiping, etc. Looks like the firmware has crashed.
12 REPLIES 12
Message 2 of 13
Re: Samsung A515 mobile has packed up
Have you tried using Google search as there are numerous suggestion and videos on YouTube of how to get phone working again
Message 3 of 13
Try a factory reset. This will clear anything that you have stored on the phone and reset it back to how it was when you first got it.
See link
How To Hard Reset A Samsung Galaxy A51 – The Droid Guy
Message 4 of 13
Yes I've looked at YT. Thanks. Unfortunately I can only get the Side button & Volume Down buttons to work which causes a restart (back to square one). It displays the screen in my photo above. Can't enter any other commands. It's completely stuck.
Message 5 of 13
Message 6 of 13
If you can not do a factory reset and your phone is still within its warranty contact the company you bought it off and report it as faulty and let them deal with it.
If it was BT that you got the phone from call 0800.800.150
Message 7 of 13
Well done In least you got a bit of help pal
Message 8 of 13
.... and you have been given advice about where you should have posted your problem in order to get help.
Re: MOBILE - BT Community
Message 9 of 13
It was a Galaxy Samsung A13 I was talking about. Never heard tell of A515
Message 10 of 13
It is a variant of the Galaxy A51. SM-A515-F/DSN
I spoke to the BT help line and subsequently sent it back to them for inspection. I am currently waiting for it to be repaired or replaced.
Problem solved.
