Message 1 of 6
Social tarrif extending to smart phone
Hi all,
For the very first time I have a smart phone and would like to connect to the internet away from home.  Can this facility be included in the Monthly bill to BT of £15.00 Social tariff?
Thanks in anticipation
5 REPLIES 5
Message 2 of 6
Re: Social tarrif extending to smart phone
Did you purchase the smart phone outright or got as gift or does it come with a call package?  you can always connect to BTWIFI/EEWIFI  free when away from home if you can find a signal.
there is no social tariff for mobile and you would probably be cheaper buying a sim only package and use that in your mobile
Message 3 of 6
Recommendation for a "sim only" please
Message 4 of 6
try google search for - uswitch  sim only deals or same search on money supermarket
probably better with monthly deal rather than 12 month contract
Message 5 of 6
Thanks!
I will not be a heavy user
Message 6 of 6
EE mobile offer a social tariff, similar criteria to BT’s offering on broadband
