Message 1 of 6
Unable to get internet connection in France
  • Am in France. Cannot get Internet connection on my Samsung A21S. I have followed BT instructions on how to set up phone before coming abroad. The ' help when abroad ' contact number for BT will not connect . No e mail address to contact BT either. Not happy with BT at present! My husband has same model of mobile  but is with Tesco and he has had no problems with Internet. Could any kind person on this forum offer advice please?
5 REPLIES 5
Message 2 of 6
Re: Unable to get internet connection in France
did you update MYBT before you left to ensure international use was on and that your spend limit was greater than £0
Message 3 of 6
Yes, I believe I updated and set my phone for use abroad as per BT instructions.
Message 4 of 6
did you also change the international spend cap from £0 to say £5.  cap has to be greater than zero
Message 5 of 6
Thank you so much for your help. I have changed the cap on international use and now the R has appeared above signal strength. Hopefully mobile will work okay now. I'll be contacting BT about this issue when I return home as it certainly wasn't made clear in the guidance. Thanks again!
Message 6 of 6
Read the section, "What do I need to do before I go abroad?"
https://www.bt.com/help/mobile/going-abroad/using-bt-mobile-abroad/how-do-i-use-bt-mobile-abroad-
