Message 1 of 4
Voicemail ring delay
I am trying to change the ring delay on my BT Mobile Voicemail from 20 seconds to 30 seconds but it seems to be stuck at 20 seconds. I use the standard MMI code **61*+447953223571*11*30# and it says it has registered but the time stays at 20 seconds.
3 REPLIES 3
Message 2 of 4
Re: Voicemail ring delay
Message 3 of 4
That is exactly what I am doing and I am getting the success message but the delay remains at 20 seconds.
Message 4 of 4
It used to work that way.
Its normally a setting on the phone itself to do with call forwarding, so it may depend on what type of phone you are using.
