Message 1 of 4
diverting mobile to landline
can I divert my BT mobile to my BT landline?
The mast is down for the area and eta is 3 days for a fix.
Obviously I have no access via the mobile unless I drive miles till I pick up an alternative so that is no help.
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: diverting mobile to landline
Does your phone not support WiFi Calling?
Message 3 of 4
I suspect that it can only be done from your mobile, for security reasons, so you may not have any alternative to drive to an area which has a signal.
Message 4 of 4
I feared as much - thought perhaps there was a way through the BT website or somesuch.
