Anonymous
Not applicable
Message 11 of 15
Re: loss of calls and texts
You mobile mast AND your intent connection have gone down at the same time? How are you posting?
Message 12 of 15
Hi @ladysky
I am sorry you are experiencing signal issues on your iPhone 16.
You can report mobile signal problems on the Service Status Checker if you select 'report a problem' the report will go to the network team to get looked into.
Can you connect to WiFi and use WiFi Calling to make and receive calls? Or, are you having problems with your broadband connection?
Speak soon.
Leanne.
Message 13 of 15
no my internet has not gone down as im posting on my desk top its just my phone
Message 14 of 15
i cant recive or make calls  my internet is fine
Anonymous
Not applicable
Message 15 of 15
